Registration takes place on the Manage Data Sources page in the CA Performance Center Console.
Note: This topic describes the steps to perform in CA Performance Center. If you install CA Network Flow Analysis and register it as a data source for CA NetQoS Performance Center, the steps are slightly different. For more information about tasks in CA NetQoS Performance Center, click Help in the CA NetQoS Performance Center Console.
Note: For information about the number of data sources that a single instance of CA Performance Center supports, see the CA Performance Center Release Notes.
Note: Tenant administrators cannot access the Manage Data Sources page.
The Manage Data Sources page displays the current list of registered data sources.
The Data Source Administration dialog opens.
Note: All CA products that can be registered as CA Performance Center data sources are shown in the Source Type list. The list is not filtered to show installed products.
The hostname is the IP address or DNS hostname of the server where the database for this data source is installed. For a distributed deployment of CA Network Flow Analysis, supply the hostname of the NFA console.
For more information, see the CA Single Sign-On User Guide.
Note: SSL can be used for communications between CA Performance Center and the data source products. For more information, see the CA Single Sign-On User Guide.
By default, the data source type and the hostname are combined to create the display name. You can supply another name. For example, instead of NetworkFlowAnalysis@xxx.x.x.xx, you can name the data source NetworkFlowAnalysis_NewYork.
The Data Source List shows the data sources that are registered.
