Previous Topic: Add and Delete HarvestersNext Topic: Customizing CA Network Flow Analysis
Edit Harvester Details
Edit the details for Harvesters on the Harvester page. You can edit the IP address, description, and tenant-domain setting.
  1. Select Administration from the NFA console menu.
  2. Select System: Harvester from the Administration page menu.
    The Harvester page opens and displays a table of information about known Harvesters.
  3. Click Edit on the Harvester row that you want to edit.
    The Edit Harvester dialog opens.
  4. (Optional) Change any of the following settings:
    IP Address
    Address of the Harvester
    Description
    (Optional) Additional information to help identify the Harvester on the Harvester page
    Domain
    The tenant-domain combination that is associated with the Harvester.
    Changing this setting affects the tenant-domain association for any new routers that begin exporting flow data and any new interfaces that begin generating flow. Already existing routers and interfaces retain their previous tenant-domain associations.
    The tenant affects which SNMP profiles are available for routers to poll interfaces. (The tenant setting is applicable only if the CA Network Flow Analysis deployment is registered as a data source for CA Performance Center.)
    The domain affects which operators and reports have access to the data from routers and interfaces.
    Default: Default Tenant\Default Domain
    If no custom IP domains have been created, the Harvester table includes only the IP Address and Description columns.
  5. Click Save when you finish making changes.
    Your changes are saved immediately and appear in the Harvester table.
