Performing Advanced Administration › Map Applications › Create an All (ToS) Application Mapping Rule
Create an All application rule to combine traffic that has a common ToS value. The All application rule lets users easily report the total traffic for a particular service type.
- Open the Application Definitions page:
- Select Administration from the NFA console menu.
- Select Application Definitions in the Administration menu.
The Application Definitions page opens.
- Verify that Application Mapping is the selected value for Rules.
- Click Add Rule.
The Add Application Mapping dialog opens.
- Select All from the list of rule types at the top of the dialog.
The Add Application Mapping dialog switches to All (ToS) rule mode.
- Specify values for the following settings:
- ToS: Type of Service (ToS) to use as a filter for the collected data. To match all ToS values, enter 0.
- Destination Port: Target port that collects the mapped data
- Name: Identifier for the rule as it is listed on the Application Definitions page
- Description: (Optional) Additional descriptive text to identify the rule type and use
- When the values are correct for all the required fields, click Save.
The Add Application Mapping dialog closes. The new rule is included in the Application Mapping rule list.
- (Optional) Run reports to verify that all of the traffic on the designated target port fits the rule.
- (Optional) Review the effects of the new or changed application mapping rules on reports, then consider renaming the protocol to identify it more clearly for other users.
