Initial Configuration › Set Up Flow Cloning › Characteristics of Cloned Packets
Cloned IP packets have the following characteristics:
- ToS value of cloned packets = 0 (zero), regardless of the original packet value. This characterizes the ToS value of the cloned packets that contain the flows. The ToS values of the traffic that the flows describe is not affected.
- Sender port = 10,000, regardless of the sender port of the original packet
- Time To Live (TTL) value = 255, regardless of the TTL value of the original packet
- Fragment ID - Arbitrary number
