Initial Configuration › Single Sign-On
Single Sign-On
The Single Sign-On tool authenticates you at start-up so you can log in once and can use several related products without logging in again. If you log in to CA Performance Center, for example, you can jump to information in CA Network Flow Analysis without logging in again.
Single Sign-On is installed automatically when you install CA Network Flow Analysis.
Notes:
- The Single Sign-On tool uses Lightweight Directory Access Protocol (LDAP) if LDAP is set up. The Single Sign-On tool does not use LDAP by default. If you upgrade from CA NetQoS ReporterAnalyzer 9.0.1, update any previous SSO LDAP configuration that you had.
- For more information about configuring the Single Sign-On tool for LDAP authentication and other options, see the Single Sign-On Guide, which is available in the CA Network Flow Analysis Bookshelf and from CA Support Online.
