This topic describes how to uninstall the CA Anomaly Detector software by using the Uninstaller. You also can uninstall the software from the Control Panel. The program is listed as AD in the Windows Add or Remove Programs or Programs and Features window.
The Uninstall window opens.
As soon as you click Next, the Cancel button is disabled. The Uninstaller has no Undo option: Once you begin uninstalling the software, you cannot restore the deleted files automatically.
The uninstall program removes the program and data files, including the following CA Network Flow Analysis and MySQL elements:
As the uninstaller runs, the screen displays progress messages. When the process is complete the screen displays a list of the directories and files that were not deleted.
Note: Leave the file system undisturbed while uninstallation is in progress. Do not attempt to view the progress in Windows Explorer, for example.
Once the program finishes, the Uninstall Complete screen opens.
Wait a few minutes to allow the helper process to finish the final cleanup.
Some files are not deleted until this phase is finished. Once the final cleanup is finished, the Uninstaller itself is deleted.
Notes:
