Previous Topic: Move a Report to Another Folder
Next Topic: Delete Saved Report Definitions
When a saved report definition is no longer needed, you can delete it. You can delete one report definition at a time, or you can delete multiple definitions in a single folder simultaneously. Be sure that you do not delete a report definition that is useful as a template for creating other reports. Deleted report definitions cannot be restored.
  1. In the Reports pane, select the check box next to all report definitions that you want to delete.
  2. Click Delete.
    A confirmation box opens.
  3. In the confirmation dialog box, click OK.
    The confirmation box closes. The list of saved report definitions is updated.
