Previous Topic: View Custom Reports
Next Topic: Create a Report Folder
Manage Custom Reports
Creating reports for your organization is key to fully exploiting the capabilities of CA Network Flow Analysis. The report definitions are saved so you can generate an updated report at any time or you can use the report as a template for another report. As the number of report definitions grows, use the folder management system to keep the reports organized and accessible.
The report folders are listed in the left pane. The Custom Reports folder is a built-in folder, which is already present when you install CA Network Flow Analysis. Create additional folders to provide more extended organization for your reports.
The right pane displays a list of the reports stored in the currently selected folder. Use the links at the top and bottom of the panel to delete, run, or move any selected reports, to create a report, or to cancel the ongoing regeneration of reports.
More information:
Rename a Report Folder
Move a Report to Another Folder
Delete Saved Report Definitions
