Administrators can create SNMP profiles in the CA Performance Center console. CA Network Flow Analysis uses SNMP profiles to query devices for data. You can create profiles for SNMPv1/v2c or for SNMPv3.
The Manage SNMP Profiles page displays the current list of SNMP profiles.
The Add SNMP Profile dialog opens.
Defines a name for the SNMP profile. Profile names must be unique, cannot be duplicated across SNMP versions, and are not case-sensitive.
Specifies the version of SNMP that the profile uses. Because SNMPv1 and SNMPv2C are similar from a security standpoint, they share a single option. SNMPv3 is a separate option.
Identifies the port that is used to make SNMP connections to devices associated with this profile.
Default: UDP 161.
(SNMPv3 Only) Identifies the user for the profile, whose secret keys were used potentially to authenticate and encrypt the SNMPv3 packets. The User Name is a character string.
(SNMPv1/v2C Only) Defines a secure string that lets the data source query the MIB of the associated device. The community that you supply must provide read-only access to the device MIB.
Note: In the default SNMP profile, the community is 'public'.
Confirms the secure community string (name).
Specifies a collection of management information that is accessible by an SNMP entity. The Context Name is necessary for providing end-to-end identification and for retrieving data from an SNMPv3 agent. The Context Name is an octet string.
Specifies the authentication protocol to use when contacting devices associated with this profile. Select one of the following algorithms for authenticating SNMPv3 packets:
Specifies the password for authentication using SNMPv3 and the selected authentication protocol.
Note: For SNMP profiles that are used with CA Network Flow Analysis, make sure you specify a password that is at least eight characters long. If the password does not meet this requirement, the SNMP profile will be invalid and no SNMP data will be returned when the SNMP profile is used for polling. In this case the corresponding interfaces and devices in views, reports, and dashboards are missing device names, interface names, interface speeds, and interface utilization data.
Confirms the authentication password.
(Optional) Specifies the encryption protocol to use for data flows sent to any devices or servers associated with this profile. Select one of the following protocols to create a valid SNMP profile for CA Network Flow Analysis polling:
Note: If AES 192 and AES 256 options are listed, do not select either of those options, as they are not supported for CA Network Flow Analysis. If the SNMP profile you create is not valid, no SNMP data is returned for devices and interfaces that use it. In this case the corresponding interfaces and devices in views, reports, and dashboards in CA Network Flow Analysis and CA Performance Center are missing device names, interface names, interface speeds, and interface utilization data.
The privacy protocol option is not enabled until authentication is enabled for this profile.
Defines the password used when exchanging encryption keys. See the Note for a possible length requirement.
Specifies whether the information in this profile is used by default. CA Performance Center uses this information to contact any new items that are discovered from monitored traffic. If it fails, the next profile in priority order is used. Disable this parameter to exclude a profile from discovery.
Note: This parameter does not apply to CA Infrastructure Management Data Aggregator data sources.
CA Performance Center automatically performs a global synchronization to send the profile information to all registered data sources.
