Verify that each Harvester is associated with the appropriate domain before you set up any router to export data to the Harvester.
Note: If you have not set up the domains you intend to use, set up the domains before you proceed. The routers that you configure to export to a Harvester are permanently associated with the domain of the parent Harvester. You can change the domain of the interfaces that are associated with the router, however.
The Harvester page opens and displays the current list of Harvesters.
The Edit Harvester dialog opens.
Default: Default Tenant\Default Domain.
You can also change the IP Address and Description.
Note: If no custom IP domains have been created, the Harvester table includes only the IP Address and Description columns.
Your changes are saved immediately.
