When a saved report definition is no longer needed, you can delete it. You can delete one report definition at a time, or you can delete multiple definitions in a single folder simultaneously. Be sure that you do not delete a report definition that is useful as a template for creating other reports. Deleted report definitions cannot be restored.
A confirmation box opens.
The confirmation box closes. The list of saved report definitions is updated.
