Previous Topic: Rename a Report Folder
Next Topic: Delete Saved Report Definitions
Move a Report to Another Folder
You can add folders and move report definitions among the folders to make the report definitions easier to find or to help identify them.
  1. Navigate to the page for the report type: Custom Reporting, Flow Forensics, or Analysis.
  2. In the Reports pane, select the check box next to all the reports that you want to move.
  3. Click Move to Folder.
    A pop-up dialog opens.
  4. Select a destination folder from the list.
  5. Click OK.
    The dialog closes. The reports are now in their new location, and are visible when you click that folder name in the Saved Report Folders pane.
