Previous Topic: Top N ToS Report
Next Topic: Top N Conversations Report
Top N Hosts Report
A Top N Hosts report provides information about the hosts that generate the most traffic on the selected interface.
The Top N Host Summary report shows activity for the most heavily used hosts.
To display a Top N Hosts report, start from an interface report.
  1. Display an interface report in either of the following ways:
  2. Select Hosts from the report type menu at the top-left corner of the page.
  3. Make sure that the report scope is set to Top N Hosts. The Top N Hosts link should appear next to the report type setting.
    The report page is updated to show host summary pie charts by default. The report includes views for the following host data:
  4. (Optional) Change the data presentation type and the data measurement type by using the Presentation options.
  5. (Optional) Change the reporting period: Open the Timeframe dialog by clicking the timeframe link.
    The reporting period is the most recent 24-hour period by default.
Display an Interface Report for a Single Host
To drill down to more detailed, host-specific data for the selected interface, click a host name in a Top N Host view. An overview report for the host on that interface opens. You can view the host details or the host protocols.
You can view this type of report in Details mode or Protocols mode, which have the following options:
To return to the summary view, click the link that is named for the currently selected host and click Select Top N Hosts.
Find Comparable Views in CA Performance Center
You can display the following host views in the CA Performance Center console:
