Previous Topic: Interface Report Types
Next Topic: Top N ToS Report
Top N Protocols Report
A Top N Protocols report provides information about the protocols that generate the most traffic on a specific interface .
Stacked Trend charts data in graphical form and include drilldown links.
To display a Top N Protocols report, start from an interface report.
  1. Display an interface report in either of the following ways:
  2. Select Protocols from the report type menu at the top-left corner of the page.
  3. Make sure that the report scope is set to Top N Protocols. The Top N Protocols link should appear next to the report type setting.
    The report page is updated to show protocol data in stacked trend charts by default. The report includes views for inbound, outbound, and total protocol data.
  4. (Optional) Change the data presentation type and the data measurement type by using the Presentation options.
    Each option displays data that is inbound and outbound with respect to the selected interface.
  5. (Optional) Change the reporting period: Open the Timeframe dialog by clicking the timeframe link.
    The reporting period is the most recent 24-hour period by default.
Note: You also can display Protocol Summary views in a Custom Report.
Open a Drilldown Protocol Report
To drill down to more detailed, protocol-specific data for the selected interface, click the name of a protocol in any of the Top N Protocol views. An overview report opens for the protocol on the selected interface.
Display an Interface Report for a Single Protocol
To drill down to details about a specific protocol, click one of the protocol links in a Top N Protocols view. A report opens, which you can display in Overview, Details, Hosts, or Conversations mode. The options in the Presentation menu are mode-specific. You can display any of the following types of data and views:
To return to the summary view of all protocols on the interface, click the link that is named for the currently selected protocol and click Select Top N Protocols.
Find Comparable Views in CA Performance Center
You can display the following Protocols views in the CA Performance Center console:
See Also:
Protocol Trend Views
Protocol Summary Views
Stacked Protocol Trend
