Introducing CA Network Flow Analysis › Related Documentation
CA provides a full set of technical documentation in the CA Network Flow Analysis Documentation Bookshelf. Access the bookshelf by clicking the Help link in the CA Network Flow Analysis user interface.
The following guides available for CA Network Flow Analysis 9.1.1:
- Online help (HTML help): Assistance for Administrators and operators, which is available through the Help link in the user interface.
- Administrator Guide (NFA_Administrator_Guide_en_US.pdf and HTML help): Information about setting up and maintaining CA Network Flow Analysis.
- User Guide (NFA_User_Guide_en_US.pdf and HTML help): Instructions for using the NFA console to create, view, and manage reports.
- Installation Guide (NFA_Installation_Guide_en_US.pdf and HTML help): Steps for installing the software and for performing some one-time configuration tasks.
- Release Notes (NFA_Release_Notes_en_US.pdf and HTML help): Summary of CA Network Flow Analysis enhancements, fixes, and open issues.
- Use Case: Register and Configure Network Flow Analysis in CA Performance Center (HTML help): Steps for registering CA Network Flow Analysis with CA Performance Center and for performing initial configuration in both consoles.
The product PDFs are installed in the following directory: <NFA_install_path>\Reporter\NetQoS.ReporterAnalyzer.WebSite\help\<locale, such as en_US, zh_CN, or ja_JP>\NFA_Bookshelf\Bookshelf_Files\PDF.
For the latest product documentation, go to the CA self-service portal at http://ca.com/support.
To view PDF files, make sure that Adobe Reader is installed. You can download the Reader from http://get.adobe.com/reader/.
