CA Network Flow Analysis provides network traffic analysis with real-time visibility into the network traffic throughout your enterprise. CA Network Flow Analysis lets you access as much as one year of flow data for your entire network.
You can access CA Performance Center from the NFA console when you add CA Network Flow Analysis as a data source in CA Performance Center. You can compare data that is collected from various sources in CA Performance Center.
Certain administrative tasks are performed in CA Performance Center--management of users, roles, permissions, SNMP profiles, and some types of groups. Install CA Performance Center and register CA Network Flow Analysis as a data source so you can use all the CA Network Flow Analysis features.
You can customize views in CA Performance Center, as described in the CA Performance Center Administrator and User Guide.
