Previous Topic: Top Hosts - Pie
Next Topic: Interface: Top Protocols
Top Hosts (Table)
The Top Hosts (Table) views show rate, volume, or utilization for the highest volume hosts on a particular interface.
The example shows a Top Hosts (Table) view that is configured to show the rate for each listed host.
The Top Hosts Table views show the hosts who are generating the most traffic on the interface.
The view contains an interface identification string and a table. The table contains a row for each host with the host name or IP address and the following rate, volume, or utilization information (by default):
By default, views and reports show the most recent 24 hours of data.
To see a Top Hosts (Table) view in CA Performance Center, add it to a custom dashboard.
Available Actions for This View
You can perform several actions in this view, including the ones in the following list:
Find Host Tables in the NFA Console
You can display tables with host volumes in the NFA console for any interface that you have selected:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
