Previous Topic: Name Routers
Next Topic: Create Reporting Periods
Create Time Filters
Create time filters to help users create reports that contain streamlined data. For example, suppose that your users need some reports that describe network traffic during business hours. You create a time filter for Monday through Friday from 8:00 A.M. to 5:00 P.M. You may also want to create time filters for the timeframes of specific operations that occur in your environment, such as automated backups.
You can also use the time filters that you create to configure traps on the Trap Configuration page.
Note: Additional information about the use of time filters is in Create Traps.
The custom time filters are available to users in Time Filter option lists in the following locations:
  1. Select Administration from the NFA console menu.
  2. Select Time Filters under the Administration: Reporting label in the Administration menu.
    The Time Filter Configuration page opens and displays a list of the currently configured time filters.
  3. Click Add.
    The Time Filter Configuration page displays options for adding a time filter.
    In Add mode, the Time Filter Configuration Page displays options for adding a time filter.
  4. Enter values for the following options:
  5. Save the time filter by clicking one of the following buttons:
Note: To delete a time filter, select it from the list of available time filters, click Delete, then confirm the deletion when prompted. To edit a time filter, select it from the list of available filters, change any of the options that are displayed, then click Submit.
