Previous Topic: Review the Active Interface Page Options
Next Topic: Edit Details for a Router, Interface, or CVI
Search for a Router, Interface, or CVI
Use the Search function on the Active Interfaces page to locate routers, interfaces, or CVIs. To search for aggregations, use the similar Search function on the Aggregation Interfaces page.
  1. Select Administration from the NFA console menu.
  2. Select Interfaces: Physical & Virtual from the Administration page menu.
    The Active Interfaces page opens and shows the list of routers.
  3. Enter a text string in the Search field. Search for whole or partial text strings that match the addresses, names, or descriptions of routers, interfaces, or CVIs.
    Note: Do not use wildcards.
  4. Click Search.
    The list is filtered to display only matching entries. If you search for interfaces or CVIs, the search returns a list of routers that contain matching items. When you expand router details, all items appear in the sublists.
To clear the search, click Clear Filter.
