Previous Topic: Role InformationNext Topic: Product Privilege
Permission Set Limitation
When bound to CA Performance Center, the CA Application Delivery Analysis management console enforces permission sets, however, the Multi-Port Monitor does not. For example, if a user has permission to a particular group of servers, and the Multi-Port Monitor can monitor at least one of the servers in the group:
If necessary, restrict CA Application Delivery Analysis data source access to avoid giving a user access to data in the Multi-Port Monitor that is outside their permission set.
Note: Restricting the Drill into Data Sources role right does not prevent a user from directly accessing the CA Application Delivery Analysis management console and Multi-Port Monitor.
