Recommended Configuration › Verify Packet Flow Through Ports
Verify that packets flow through the ports to determine that installation of the hardware and software was successful.
- Click System Status in the web interface.
- Review the Capture Card Physical Port Status section for the following information:
- Which ports are connected on the adapter.
- The number of packets that are received through each port.
Configuration is successful if the ports are active.
