Previous Topic: Byte Counts for Networks and HostsNext Topic: Exporting Data
Add or Remove Columns in a Data Table
By default, some data is excluded from the data table on the Traffic and TCP tabs. You can include more columns of data.
  1. Click Edit Columns.
    The Edit Columns dialog opens.
  2. Select the check boxes for the metrics you want to add to the data table.
  3. Clear the check boxes for the metrics you want to remove from the data table.
  4. Click Default to restore default column settings.
  5. Click Save.
    Your changes are reflected in the data table after it refreshes.
