Previous Topic: Delete an Analysis FilterNext Topic: Global Filters Dialog
Global Filters
Global filters are inherited from the CA Application Delivery Analysis report context that was in effect when you initiated a Session Analysis. Each global filter setting indicates the context.
A list of active global filters appears at the top of the Analysis pane. Domain, Application, Server, and Network global filters appear first, and then the Logical Port that was selected during the Session Analysis procedure.
Queries to the Multi-Port Monitor database filter the data. The queries depend on the type of filter and on the selected data view, and are selected to optimize the data that is returned.
You can modify a global filter to limit the data that is presented in the Display area. You can also clear a global filter to return it to the default setting.
