The Display area contains a chart and a data table. The following items affect the data in the chart and table:
The chart provides a series of format buttons down the right side to let you apply other chart formats for the same data. You can expand the size of the Display area by hiding the Analysis pane. Click the Hide icon (<<) on the Analysis pane to hide it.
The chart and table are linked so that they always display data in complementary formats. The table displays more data than the chart. However, the chart reflects the filters that you apply to the table, such as changing the sort order and selecting a new page.
The data table presents performance data for troubleshooting and analysis. You can sort each column to view outliers and minimum results. Two filters always affect the data table:
A predefined analysis includes minimal filters and applies some logic to limit the data to a manageable quantity. This technique speeds up database queries and also makes the Display area more coherent for the typical user.
Data from the first ten table rows is represented in the chart for all but the Summary Trend chart. The Summary Trend chart reflects data from all table rows. You can display more table rows by increasing the Max Per Page setting.
This section contains the following topics:
