To review the processing status of batch jobs and to see some statistical information about processed job steps, select option 3 on the Maintenance Menu.
APCXP800 --- PMA - Central Component Job Log ------------------- Row 2 from 38 COMMAND ===> SCROLL ===> HALF Show : S Short/Long ------------------------------------------------------------------------------- #>>>>>> START APCYALST 2011-02-23 4:39 PMA COLLECTING MEASUREMENT PROFILES #<<<<<< ENDED APCYALST 2011-02-23 4:39 CONDITION CODE: 00 #<<<<<< ENDED APCYALST 2011-02-23 4:39 CONDITION CODE: 00 #>>>>>> START APCYALST 2011-02-23 4:40 PMA COLLECTING MEASUREMENT PROFILES #<<<<<< ENDED APCYALST 2011-02-23 4:40 CONDITION CODE: 00 #<<<<<< ENDED APCYALST 2011-02-23 4:40 CONDITION CODE: 00 #>>>>>> START APCYANAR 2011-02-23 4:40 PMA PROCESSING OF MEASUREMENT LISTS #<<<<<< ENDED APCYANAR 2011-02-23 4:40 CONDITION CODE: 00 #>>>>>> START APCYANAR 2011-02-23 4:40 PMA PROCESSING OF MEASUREMENT LISTS #<<<<<< ENDED APCYANAR 2011-02-23 4:40 CONDITION CODE: 00 ******************************* Bottom of data ********************************
For the most current production cycle, batch jobs of the Central Component are displayed along with a processing summary and statistics for each of the following batch job steps.
Both long and short views of the available job log information can be selected. A short view of information is displayed as the default when the Job Log option is entered on the Maintenance Menu. A long view of the information includes the processing statistics for each job. To switch between short and long views, enter S or L in the Show field. The following example is a panel that illustrates the information available with the long view.
APCXP800 --- PMA - Central Component Job Log ------------------- Row 1 from 38 COMMAND ===> SCROLL ===> HALF Show : L Short/Long ------------------------------------------------------------------------------- #>>>>>> START APCYALST 2011-02-23 4:39 PMA COLLECTING MEASUREMENT PROFILES #<<<<<< ENDED APCYALST 2011-02-23 4:39 CONDITION CODE: 00 THE PMA PREFIX FOR REPORT DS DID NOT MATCH WITH ANY EXISTING DATA SET NAME. #<<<<<< ENDED APCYALST 2011-02-23 4:39 CONDITION CODE: 00 #>>>>>> START APCYALST 2011-02-23 4:40 PMA COLLECTING MEASUREMENT PROFILES #<<<<<< ENDED APCYALST 2011-02-23 4:40 CONDITION CODE: 00 >>> JOB GENERATED TYPE = CICS JOB# = 001 MEMBER# = 001 >>> JOB GENERATED TYPE = BATCH JOB# = 002 MEMBER# = 001 #<<<<<< ENDED APCYALST 2011-02-23 4:40 CONDITION CODE: 00 #>>>>>> START APCYANAR 2011-02-23 4:40 PMA PROCESSING OF MEASUREMENT LISTS APCYANAR TOTAL STATISTIC FROM DATE 2011-02-23 ============================================================================== BATCH PROFILES HANDLED 0000 CICS PROFILES HANDLED 0001 IMS PROFILES HANDLED 0000 ERROR PROFILES HANDLED 0000 TOTAL PROFILES HANDLED 0001 ============================================================================== APCYANAR ENDED SUCCESSFUL USED TIME 0004 SEC #<<<<<< ENDED APCYANAR 2011-02-23 4:40 CONDITION CODE: 00 APCYANAR TOTAL STATISTIC FROM DATE 2011-02-23 ============================================================================== BATCH PROFILES HANDLED 0001 CICS PROFILES HANDLED 0000 IMS PROFILES HANDLED 0000 ERROR PROFILES HANDLED 0000 TOTAL PROFILES HANDLED 0001 ============================================================================== APCYANAR ENDED SUCCESSFUL USED TIME 0001 SEC #<<<<<< ENDED APCYANAR 2011-02-23 4:40 CONDITION CODE: 00
