When running in a CA MAT environment, the IMS Feature is divided into the following parts:
All the JCL illustrated in this chapter should be customized by replacing lower case italicized items with values that suit the needs of your environment. All JCL can be found in your product CNTL library.
The use of a job scheduling system to run the jobs on a regular basis is strongly recommended. All steps are fully restartable.
