When you choose option C3 on the Parameters Menu, the following panel is displayed. Use this panel to enter the load module libraries Performance Management Assistant should examine.
APCBPP05 --- PMA CICS Feature - List Load Libraries ---------- Row 1 to 2 of 2 COMMAND ===> SCROLL ===> HALF Commands : INS Insert CAN Cancel END Exit and Save Line Commands: I - Insert D - Delete C - Change LC Dataset name ------------------------------------------------------------------------------- PROD.CICS.LOAD1 PROD.CICS.LOAD2 ******************************* Bottom of data ********************************
If you have not previously entered any load libraries, the insert panel is displayed and you are requested to enter the name of the load module library to be examined.
The load libraries defined here are examined in batch to determine whether programs have been modified.
If a new load library is defined, Performance Management Assistant detects the library automatically and prevents all pre-existing modules in the new load library from being treated as new modules regarding measurement.
