Previous Topic: General ParametersNext Topic: Line Commands
CICS Feature System Control
The System Control panel is displayed when option C2 on the PARAMETERS selection window is chosen.
APCDPP02 --- PMA CICS Feature - System Control --------------- Row 1 to 2 of 2 COMMAND ===> SCROLL ===> HALF Commands : CAN - CANcel INS - INSert Line Commands: I - Insert D - Delete C - Change System name LC PMA PMA Jobname Start time HH internal ID System name from to ------------------------------------------------------------------------------- 001 CICS1 CICSSYS1 00 24 002 CICS2 CICSSYS2 00 24 ******************************* Bottom of data ********************************
The System Control panel shows you the default processing results of job APCYJLNA. APCYJLNA adds a new entry in this list for every new job name of a CICS region that is processed. By default, each new entry is added with a new distinct internal ID and the job name is used as the system name.
When creating system names, consider using appropriate definitions for the later easy use of wildcards for selecting systems that should be included for reporting or other tasks.
The following functions can be performed using the System Control panel:
With the CICS feature, information about measurements can be aggregated to information for a whole online system. To understand this concept, assume the following parameters:
ID
System Name
Jobname
Start time from/to
8
MRO
AOR1CICS
00  24
8
MRO
AOR2CICS
00  24
8
MRO
AOR3CICS
00  24
Using the illustration above as an example, all measurements of CICS regions AOR1CICS, AOR2CICS, and AOR3CICS are interpreted and calculated by Performance Management Assistant to one logical system MRO. In the online dialog, the data of the measurements is seen as one although a transaction is called in all three regions. Thus, Performance Management Assistant aggregates the data of three measurements. For controlling transaction performance, look in the online dialog for the specific transaction in system MRO as one line of information.
ID
System name
Jobname
Start time from/to
28
CIC1MORN
JOBCIC1
00  12
29
CIC1LATE
JOBCIC1
12  24
Change the parameter or the schedule plan for job APCCJINV accordingly.
