The load library CAMAT.PMA.CEETAUTH contains all the Server modules that must run with APF authorization.
For more information about assigning APF authorization to this library, see Assigning APF authorization to the authorization library.
During evaluation of the Server, member LNKLSTxx of the SYS1.PARMLIB need not be modified because the Server can also run with a STEPLIB DD statement. However, to run the Server in a production environment, the APF-authorized library CAMAT.PMA.CEETAUTH should be added to your LINKLIST.
