Administration of the Central Component › Batch Jobs › Program APCBAREO
Program APCBAREO
Program APCBAREO deletes the information that has expired based on the user defined lifetime. All deleted entries are reported in the SYSOUT DD statement APCREP. The program consists of the following parts:
- The Central Component KSDS clusters are checked. Each entry is compared against the user-defined lifetime (see the Delete job data if older than parameter in section General Parameters). If the lifetime is expired, meaning the job step has not executed during the last nn number of months, the job entry is discarded and all corresponding entries in the alert files and measurements, too.
- All alert entries of the Central Component are compared with the corresponding lifetime values for certain alert states that may be user defined in Alert Delete Options. If the lifetime of the alert is expired, the alert entry is deleted. See Central Component Alert Delete Options for more information about deleting alerts.
