Previous Topic: Job APCYJLST - Evaluate Sample Data SetsNext Topic: Scheduling Batch Jobs
Job APCYJLNA- Interpret CA MAT Measurements List
Job APCYJLNA performs the following functions:
At DD name APCSALT, each new alert that is opened is provided along with the relevant alert information. This makes it very easy to use this file and the information for further processing in any organization. Using a simple REXX procedure, the key data is easy to gather and use in a problem management product or a mailing facility. Alerts for job steps and CICS or IMS transactions are provided.
The following example is an example of a job step alert.
$$ALERT
$RQ=Q                                   CA MAT REQUEST A(CTIVE) / Q(UEUED)
$JN=PRLZ1770LZPROC1 LZSTP02            JOBSTEP NAME
$SD=2010-01-04                         SESSION DATE AS YYYY-MM-DD
$ET=0043                               ELAPSED (SESSION) TIME IN MINUTES
$CT=0012                               CPU TIME IN MINUTES
$WT=0017                               WAIT TIME IN MINUTES
$EX=00000000                           EXCPS IN THOUSANDS
$AT=006                                ALERT TEXT WITH NNN LINES
2010-01-04 PMA ALERT ID 16049    BY SRVU
           JOB: PRLZ1770 LZPROC1  LZSTP02   PGM: P5LZ770
           EXEC: 2010-01-03  22:00  SYS: DSYS      CC: 0000
           CPU: 00012  ELPSD: 00037  EXCPS: 000000  SRVU: 036559  I: 23
$$ALEND
The following example is an example of a transaction alert.
$$ALERT
$SS=CICS                               SUBSYSTEM ( CICS / IMS )
$SN=PNP1                               SYSTEM NAME
$TX=OKSS                               TRANSACTION NAME
$CM=00627                              MEASURED CPU TIME %
$CA=00022                              AVERAGE CPU TIME %
$AT=005                                ALERT TEXT WITH NNN LINES
2010-01-09 PMA ALERT ID 16187    BY STAT
           TRANSACTION : OKSS       SYSTEM : PNP1       PGM : CIC1PNP1
           CPU%  MEAS  :   6.27   AVERAGE :    .22   STD.DEV :    .24
$$ALEND
The program report (DD statement APCREP) provides a detailed overview of the activities per list data set. Every measurement is interpreted only once. So if the scopes of work are changed, the new scopes are only considered on an ongoing basis.
The following example is a JCL illustration of Job APCYJLNA.
...JOBCARD
//*     PMA: APCYJLNA                                                *
//* MAINTENANCE: PMA TEAM                                            *
//* FUNCTION:    DAILY INTERPRETATION OF NEW PMA INITIATED           *
//*              CA MAT MEASUREMENTS. THE LISTS ARE NOW PROVIDED    *
//*              BY CA MAT.                                         *
//* Copyright (C) 2012 CA. All Rights Reserved.
//* Copyright (C) Trilog AG.
//* DEL    TEMPFILE
//IDCAMS   EXEC PGM=IDCAMS
//SYSPRINT  DD  SYSOUT=T
//SYSOUT    DD  SYSOUT=T
//SYSTSPRT  DD  SYSOUT=T
//SYSIN     DD  *
        DELETE CAMAT.PMA.TEMPFILE.NARROW
        DELETE CAMAT.PMA.TEMPFILE.CATN
        DELETE CAMAT.PMA.TEMPFILE.CMDN
SET MAXCC=0000
//* CREATE TEMPFILE
//IEFBR14A EXEC PGM=IEFBR14
//TEMPNARR DD DSN=CAMAT.PMA.TEMPFILE.NARROW,
//            DISP=(MOD,CATLG),
//            DCB=(RECFM=FB,LRECL=80),
//            SPACE=(CYL,(2,2)),
//            UNIT=SYSDA
//TEMPCAT  DD DSN=CAMAT.PMA.TEMPFILE.CATN,
//            DCB=(RECFM=FBA,LRECL=121,BLKSIZE=23474),
//            SPACE=(TRK,(1,1)),
//            UNIT=SYSDA
//TEMPCMD  DD DSN=CAMAT.PMA.TEMPFILE.CMDN,
//            SPACE=(TRK,(1)),
//            UNIT=SYSDA
//* INTERPRETE CA MAT PROFILE
//APCYANAR EXEC PGM=APCYANAR,PARM='L'
//STEPLIB  DD DSN=CAMAT.PMA.CEETLOAD,
//            DISP=SHR
//SYSUDUMP DD SYSOUT=*
//LISTCMD  DD DSN=CAMAT.PMA.TEMPFILE.CMDN,
//            DISP=(SHR,,DELETE)
//LISTCAT  DD DSN=CAMAT.PMA.TEMPFILE.CATN,
//APCNAR   DD DSN=CAMAT.PMA.TEMPFILE.NARROW,
//            DISP=SHR
//APCPARAM DD DSN=CAMAT.PMA.PARMS,
//            DISP=SHR
//APCJLOG1 DD DSN=CAMAT.PMA.LOG,
//            DISP=MOD
//APCBIPP1 DD DSN=CAMAT.PMA.RRDSIPP,
//            DISP=SHR
//APCBCPP1 DD DSN=CAMAT.PMA.RRDSCPP,
//            DISP=SHR
//APCBPRO1 DD DSN=CAMAT.PMA.KSDSPRO,
//            DISP=SHR
//APCBBPM1 DD DSN=CAMAT.PMA.KSDSBPM,
//            DISP=SHR
//APCBALT1 DD DSN=CAMAT.PMA.KSDSALT,
//            DISP=SHR
//APCBLMO1 DD DSN=CAMAT.PMA.KSDSLMO,
//            DISP=SHR
//APCBJOB1 DD DSN=CAMAT.PMA.KSDSJOB,
//            DISP=SHR
//APCIPRO1 DD DSN=CAMAT.PMA.KSDSIMS,
//            DISP=SHR
//APCCPRO1 DD DSN=CAMAT.PMA.KSDSCIC,
//            DISP=SHR
//APCBSQL1 DD DSN=CAMAT.PMA.KSDSSQL,
//            DISP=SHR
//PRINTPRF DD SYSOUT=*
//APCSALT  DD SYSOUT=*
//APCEREP  DD SYSOUT=*
//APCREP   DD SYSOUT=*
//SYSOUT   DD SYSOUT=*
//*   APCLIST MUST BE THE LAST STATEMENT IN THIS JCL MBR
//APCLIST  DD *
