Previous Topic: Defining Access RightsNext Topic: Changing Temporary Data Set Name
Defining System Image Name
Variable APCSIMG defines the system image name to be displayed on all panels. This parameter is required and must be eight characters. It should uniquely identify each environment on which Performance Management Assistant is installed, that is, test, production, preproduction. For example, if REXX procedure PMA is installed on the production system, the value might be PROD123U meaning this product is on a production system. If you do not want to define a system image name, the value of APCSIMG should be filled with eight dashes, that is,
