For the purpose of testing your product installation and as a quick start to using the product, you can integrate existing measurement data sets into PMA. Otherwise, for the more extensive steps necessary to use the product effectively, see Getting Started in 10 Steps.
Integration of any existing measurement data sets allows you to view or print the reports of these data sets by using the online dialog. The data from these reports may be reduced by defining scopes of work.
Display the Central Component online panels and enter all necessary general parameters; see Parameter Administration. After the parameters are defined and saved, submit job APCYJLST (found in your product CNTL library).
Important Parameters |
Delete measurement data set Print measurements automatically Aut. storage of measurements in PMA Prefix for measurement data sets Scope of work TOP Scope |
The prefix for measurement data sets, as defined in the parameter panel, must be the same as the prefix of the existing measurement data sets. If not, job APCYJLST does not recognize the measurement data sets as being controlled by PMA. If necessary, call the Global Sample DS Processing panel and change the data set name prefix to the value of the existing data set prefixes.
