Previous Topic: OverviewNext Topic: Reducing the Scope of Work
Planning your Approach
Because of performance problems resulting from poorly written applications and programs, performance measurement and correction are important. The Central Component features can best be utilized by first planning your approach. The types of approach you should consider are as follows:
Gathering this information for input to Performance Management Assistant ensures that only relevant measurements are performed and are reported.
