After selecting Step 12, the following panel is displayed.
CUSTPT12 -------------- PMA V90 Customization - Upgrade----------------------- COMMAND ===> In case of an upgrade, enter the release number, e.g. 85 for release 8.5 or 46 for release 4.6. The upgrade to version 9.0 is possible with: Release ID PMA 8.5 85 APC 4.6 46 APC 4.5.0 450 APC 4.4.3 443 APC 4.4.2 442 PMA upgrading from release: ??? CANCEL: CAN SAVE: ENTER
With version 4.5, the record layout of the JOB KSDS, CICS KSDS, and IMS KSDS has completely changed to provide more information. With version 4.6, the record layout of the DIC KSDS and CST KSDS has changed. Depending on the version that you have formerly used, it is necessary to execute the corresponding upgrade job to convert the data into the new data structures if you want to use your previous data. The data upgrade to 9.0 can be done from versions 4.4.2, 4.4.3, 4.5.0, and 4.6.
The JCL of the corresponding upgrade job for the version number that you entered is displayed.
The following sections in this chapter show JCL samples for the upgrade jobs from each of the previous versions:
You can specify CANCEL to go back to the Customization Main Menu without saving any entered value. The status of Step 11 stays NOT COMPLETED.
After the successful execution of the upgrade job, Step 12 is marked as COMPLETED.
CUSTPT00 ------------------- PMA V90 Customization Dialog --------------- COMMAND ===> Step Status =============================================================== 12 Upgrade COMPLETED
