Previous Topic: Step 9 – Create the Start ExecNext Topic: Step 11 – Customize Measurement Product Interface
Step 10 – Create JCL Members and JCL Procs
After selecting Step 10, the panel shown following is displayed.
CUSTPT10 --- PMA V90 Customization - Create PMA JCL Member and JCL Procs ----- COMMAND ===> Please provide the following definitions of related products: Name of the load library of the measurement product: DSN: your-measurement-product-load-library CANCEL: CAN SAVE: ENTER
This panel requests additional input information for building the JCL members for the batch jobs and Server procedures.
  1. Enter the value for the field listed following.
    DSN
    Specifies the data set name of your measurement product load library.
    You can specify CANCEL to go back to the Customization Main Menu without saving any entered value. The status of Step 10 stays NOT COMPLETED.
  2. Press Enter to generate the JCL members for the PMA batch jobs and Server procedures, as shown following.
    These members are saved in the PMA CNTL library.
    CAMAT.PMA.CNTL(APCBCCRI) GENERATED CAMAT.PMA.CNTL(APCBCDAX) GENERATED CAMAT.PMA.CNTL(APCBCJEX) GENERATED CAMAT.PMA.CNTL(APCBCNUL) GENERATED CAMAT.PMA.CNTL(APCCCEXP) GENERATED CAMAT.PMA.CNTL(APCCCINV) GENERATED CAMAT.PMA.CNTL(APCICEXP) GENERATED CAMAT.PMA.CNTL(APCICINV) GENERATED CAMAT.PMA.CNTL(APCKCCPT) GENERATED CAMAT.PMA.CNTL(APCXCAEX) GENERATED CAMAT.PMA.CNTL(APCXCREP) GENERATED CAMAT.PMA.CNTL(APCBJCRI) GENERATED CAMAT.PMA.CNTL(APCBJDAX) GENERATED CAMAT.PMA.CNTL(APCBJEXP) GENERATED CAMAT.PMA.CNTL(APCBJINV) GENERATED CAMAT.PMA.CNTL(APCBJPRE) GENERATED CAMAT.PMA.CNTL(APCBJRDR) GENERATED CAMAT.PMA.CNTL(APCBJREO) GENERATED CAMAT.PMA.CNTL(APCBJTRM) GENERATED CAMAT.PMA.CNTL(APCBJTRS) GENERATED CAMAT.PMA.CNTL(APCCJAPD) GENERATED CAMAT.PMA.CNTL(APCCJC46) GENERATED CAMAT.PMA.CNTL(APCCJEXP) GENERATED CAMAT.PMA.CNTL(APCCJINV) GENERATED CAMAT.PMA.CNTL(APCCJLIB) GENERATED CAMAT.PMA.CNTL(APCCJRDR) GENERATED CAMAT.PMA.CNTL(APCCJSMF) GENERATED CAMAT.PMA.CNTL(APCCJTRM) GENERATED CAMAT.PMA.CNTL(APCCJTRS) GENERATED CAMAT.PMA.CNTL(APCDJREO) GENERATED CAMAT.PMA.CNTL(APCIJAPD) GENERATED CAMAT.PMA.CNTL(APCIJEXP) GENERATED CAMAT.PMA.CNTL(APCIJIFU) GENERATED CAMAT.PMA.CNTL(APCIJINV) GENERATED CAMAT.PMA.CNTL(APCIJLIB) GENERATED CAMAT.PMA.CNTL(APCIJM44) GENERATED
    CAMAT.PMA.CNTL(APCIJRDR) GENERATED CAMAT.PMA.CNTL(APCIJS34) GENERATED CAMAT.PMA.CNTL(APCIJTRM) GENERATED CAMAT.PMA.CNTL(APCIJTRS) GENERATED CAMAT.PMA.CNTL(APCKJCPT) GENERATED CAMAT.PMA.CNTL(APCSJSIP) GENERATED CAMAT.PMA.CNTL(APCSJSTC) GENERATED CAMAT.PMA.CNTL(APCXJAPD) GENERATED CAMAT.PMA.CNTL(APCXJEBM) GENERATED CAMAT.PMA.CNTL(APCXJEP3) GENERATED CAMAT.PMA.CNTL(APCXJEP4) GENERATED CAMAT.PMA.CNTL(APCXJEXP) GENERATED CAMAT.PMA.CNTL(APCXJINV) GENERATED CAMAT.PMA.CNTL(APCXJLIB) GENERATED CAMAT.PMA.CNTL(APCXJRDR) GENERATED CAMAT.PMA.CNTL(APCXJREO) GENERATED CAMAT.PMA.CNTL(APCXJSMF) GENERATED CAMAT.PMA.CNTL(APCXJTRM) GENERATED CAMAT.PMA.CNTL(APCXJTRS) GENERATED CAMAT.PMA.CNTL(APCYJLNA) GENERATED CAMAT.PMA.CNTL(APCYJLST) GENERATED CAMAT.PMA.CNTL(APCYJNAR) GENERATED CAMAT.PMA.CNTL(APCYJNAS) GENERATED CAMAT.PMA.CNTL(APCYJSUB) GENERATED ***
  3. Press Enter to save the generated JCL members in the CNTL library.
    Step 10 is marked as COMPLETED, as shown following, and you can continue with Step 11.
    CUSTPT00 ------------------- PMA V90 Customization Dialog --------------- COMMAND ===> 11 Step Status =============================================================== 10 Create PMA JCL Member and JCL Procs COMPLETED
