Previous Topic: Step 7 – Create User Data SetsNext Topic: Step 9 – Create the Start Exec
Step 8 – Create the Data Cluster
After selecting Step 8, the VSAM definition members for the data cluster creation process are generated and saved in the CNTL library, as shown following.
CAMAT.PMA.CNTL(DEDEFALT) GENERATED CAMAT.PMA.CNTL(DEDEFBPM) GENERATED CAMAT.PMA.CNTL(DEDEFCIC) GENERATED CAMAT.PMA.CNTL(DEDEFCMO) GENERATED CAMAT.PMA.CNTL(DEDEFCPP) GENERATED CAMAT.PMA.CNTL(DEDEFCSC) GENERATED CAMAT.PMA.CNTL(DEDEFCST) GENERATED CAMAT.PMA.CNTL(DEDEFDIC) GENERATED CAMAT.PMA.CNTL(DEDEFEXC) GENERATED CAMAT.PMA.CNTL(DEDEFIMO) GENERATED CAMAT.PMA.CNTL(DEDEFIMS) GENERATED CAMAT.PMA.CNTL(DEDEFIPP) GENERATED CAMAT.PMA.CNTL(DEDEFJOB) GENERATED CAMAT.PMA.CNTL(DEDEFLMO) GENERATED CAMAT.PMA.CNTL(DEDEFPRO) GENERATED CAMAT.PMA.CNTL(DEDEFSQL) GENERATED CAMAT.PMA.CNTL(DEFINALT) GENERATED CAMAT.PMA.CNTL(DEFINBPM) GENERATED CAMAT.PMA.CNTL(DEFINCIC) GENERATED CAMAT.PMA.CNTL(DEFINCMO) GENERATED CAMAT.PMA.CNTL(DEFINCPP) GENERATED CAMAT.PMA.CNTL(DEFINCSC) GENERATED CAMAT.PMA.CNTL(DEFINCST) GENERATED CAMAT.PMA.CNTL(DEFINDIC) GENERATED CAMAT.PMA.CNTL(DEFINEXC) GENERATED CAMAT.PMA.CNTL(DEFINIMO) GENERATED CAMAT.PMA.CNTL(DEFINIMS) GENERATED CAMAT.PMA.CNTL(DEFINIPP) GENERATED CAMAT.PMA.CNTL(DEFINJOB) GENERATED CAMAT.PMA.CNTL(DEFINLMO) GENERATED CAMAT.PMA.CNTL(DEFINPRO) GENERATED CAMAT.PMA.CNTL(DEFINSQL) GENERATED CAMAT.PMA.CNTL(REPROALT) GENERATED CAMAT.PMA.CNTL(REPROBPM) GENERATED CAMAT.PMA.CNTL(REPROCIC) GENERATED CAMAT.PMA.CNTL(REPROCMO) GENERATED CAMAT.PMA.CNTL(REPROCPP) GENERATED CAMAT.PMA.CNTL(REPROCST) GENERATED CAMAT.PMA.CNTL(REPRODIC) GENERATED CAMAT.PMA.CNTL(REPROEXC) GENERATED CAMAT.PMA.CNTL(REPROIMO) GENERATED CAMAT.PMA.CNTL(REPROIMS) GENERATED CAMAT.PMA.CNTL(REPROIPP) GENERATED CAMAT.PMA.CNTL(REPROJOB) GENERATED CAMAT.PMA.CNTL(REPROLMO) GENERATED CAMAT.PMA.CNTL(REPROPRO) GENERATED CAMAT.PMA.CNTL(REPROSQL) GENERATED ***
  1. When all CNTL members are generated, press Enter to display the CUSTJT08 job to create the data cluster.
    //JOBNAME JOB(ACCOUNT),'PMA',CLASS=A,
    //             MSGLEVEL=(1,1),MSGCLASS=H,NOTIFY=&SYSUID,REGION=0M
    //* CUSTJT08:   CREATE PMA DATA CLUSTER                              *
    //* COPYRIGHT (C) 2012 CA. ALL RIGHTS RESERVED.                      *
    //* COPYRIGHT (C) TRILOG AG.                                         *
    //*    CREATE TEMP FILES
    //CREATE   EXEC  PGM=APCBAB24
    //STEPLIB  DD DISP=SHR,
    //            DSN=CAMAT.PMA.CEETLOAD
    //BLANK24  DD DSN=&&BLANK24,DISP=(NEW,PASS),
    //            UNIT=SYSDA,
    //            VOL=SER=VOL001,
    //            SPACE=(TRK,(1,1))
    //*    CREATE PMA ALERT CLUSTER
    //APCALT  EXEC PGM=IDCAMS
    //SYSPRINT DD SYSOUT=*
    //TEMP     DD DISP=SHR,DSN=CAMAT.PMA.CEETSAMP(CUSTNULL)
    //SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINALT)
    //         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROALT)
    //*    CREATE PMA BATCH PROFILE MANAGEMENT CLUSTER
    //APCBPM  EXEC PGM=IDCAMS
    //SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINBPM)
    //         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROBPM)
//*    CREATE PMA SQL STATEMENT CLUSTER
//APCSQL  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINSQL)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROSQL)
//*    CREATE PMA CICS MEASUREMENT DATA CLUSTER
//APCCIC  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINCIC)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROCIC)
//*    CREATE PMA CICS MEASUREMENT LISTING CLUSTER
//APCCPP  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINCPP)
//*    CREATE PMA SCOPE DEFINITION CLUSTER (IN/EXCLUSIONS)
//APCEXC  EXEC PGM=IDCAMS
//TEMP     DD DISP=SHR,DSN=CAMAT.PMA.CEETSAMP(CUSTINEX)
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINEXC)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROEXC)
//*    CREATE PMA IMS MEASUREMENT LISTING CLUSTER
//APCIMS  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINIMS)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROIMS)
//APCIPP  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINIPP)
//*    CREATE PMA JOB INFORMATION CLUSTER
//APCJOB  EXEC PGM=IDCAMS
//TEMP     DD DISP=SHR,DSN=CAMAT.PMA.CEETSAMP(CUSTBLAN)
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINJOB)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROJOB)
//*    CREATE PMA LOAD MODULE INFORMATION CLUSTER
//APCLMO  EXEC PGM=IDCAMS
//TEMP     DD DISP=(OLD,PASS),DSN=&&BLANK24
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINLMO)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROLMO)
//*    CREATE PMA CICS LOAD MODULE INFORMATION CLUSTER
//APCCMO  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINCMO)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROCMO)
//*    CREATE PMA IMS LOAD MODULE INFORMATION CLUSTER
//APCIMO  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINIMO)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROIMO)
//*    CREATE PMA BATCH MEASUREMENT EXTRACT CLUSTER
//APCPRO  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINPRO)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROPRO)
//*    CREATE PMA CICS SMF/IMS INFO DICTIONARY CLUSTER
//APCDIC  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINDIC)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPRODIC)
//*    CREATE PMA CICS SMF/IMS INFO DATA CLUSTER
//APCCST  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINCST)
//         DD DISP=SHR,DSN=CAMAT.PMA.CNTL(REPROCST)
//*    CREATE PMA SERVER CROSS COMMUNICATION CLUSTER
//APCCSC  EXEC PGM=IDCAMS
//SYSIN    DD DISP=SHR,DSN=CAMAT.PMA.CNTL(DEFINCSC)
//*  LOAD FIRST REC IN PMA       C I C S    P R O F I L E   P O O L *
//INIT1    EXEC  PGM=APCXAVI0
//APCBIPP1 DD DISP=SHR,
//            DSN=CAMAT.PMA.RRDSCPP
//APCEREP  DD SYSOUT=*
//*  LOAD FIRST REC IN PMA       I M S    P R O F I L E   P O O L   *
//INIT2    EXEC  PGM=APCXAVI0
//            DSN=CAMAT.PMA.RRDSIPP
//*  LOAD FIRST REC IN PMA       C S C    PMA-SERVER COMPONENT FILE *
//INIT3A   EXEC PGM=IEBDG
//SEQOUT   DD  DSNAME=&&REPIN,UNIT=SYSDA,DISP=(,PASS),
//             DCB=(RECFM=FB,LRECL=108,BLKSIZE=1080),
//             SPACE=(TRK,(1))
//SYSIN    DD  DATA
   DSD OUTPUT=(SEQOUT)
   CREATE QUANTITY=1,FILL=X'FF'
   END
//INIT3B   EXEC PGM=IDCAMS
//IN       DD  DSN=&REPIN,DISP=(OLD,DELETE)
//OUT      DD  DSN=CAMAT.PMA.KSDSCSC,
//             DISP=OLD
//SYSIN    DD  *
 REPRO INFILE(IN) OUTFILE(OUT)
//*    WRITE PMA CUSTOMIZATION NOTIFICATION MESSAGE
//NOTIFY   EXEC PGM=IEBGENER,COND=(0,NE)
//SYSUT1   DD DISP=SHR,
//            DSN=CAMAT.PMA.CUST(CUST$JOB)
//         DD *
2011/02/22 07:35  #8 CUSTJT08   CREATE PMA DATA CLUSTER - SUCCESSFUL
//SYSUT2   DD DISP=SHR,
//SYSIN    DD DUMMY
  1. Review the JCL in the CUSTJT08 job.
  2. Choose one of the following actions:
    The status of Step 8 stays NOT COMPLETED.
