Previous Topic: Repository Import/Export (TRIX)
Next Topic: Report Explorer
Global Catalog
The Global Catalog is a directory of all installed CA product components. During installation, you select a common device to be used as the Global Catalog and then choose the Global Catalog machine whenever you install a component. The installed component publishes its existence to the Global Catalog.
When the MCC launches, it synchronizes with the Global Catalog to display all CA product components currently installed in your organization. Any MCC that uses the Global Catalog can see all of the deployed components throughout the organization.
