CCS is installed quickly and easily as part of your CA product so you do not have to worry about additional installations or difficult deployments. CCS also provides significant resource savings, because only those components that are actually required get installed. The desired components are selected from a menu of items in visualization, management, and infrastructure services. CCS offers great flexibility in the selection of suitable components, as indicated by the following partial list of components in the CCS bundle.
CCS Component |
Function |
Event Management |
Management |
Common Enterprise Tools |
Infrastructure |
WorldView 2D Map Interface |
Visualization |
WorldView 3D Map Interface |
Visualization |
WorldView Common Services |
Infrastructure |
Common Communications |
Infrastructure |
Report Explorer |
Visualization |
Agent Technology Common Services |
Infrastructure |
Management Command Center |
Visualization |
Agent Technology Distributed State Machine |
Management |
Event Wireless Management |
Management |
ManagedPC Components |
Management |
CCS includes runtime modules and provides a Software Development Kit (SDK) for third parties to integrate the runtimes with your CA product and to facilitate the rapid incorporation of specific CA technologies.
Tip: For more information about the Software Development Kit, see the CA SDK Developer Guide. Each CA solution has the runtime modules it requires embedded in the product.
Any third‑party product that is enhanced with the Software Development Kit can communicate and integrate with any of the CA solutions containing the specific common services (such as Event Management) for which an integration has been performed.
Two typical scenarios when a vendor or third-party can use CCS are as follows:
Note: Not all CCS components are available on every platform. Virus Scan, for example, is available only on Windows.
