Previous Topic: Server Process Logfile
Next Topic: Entering a Proxy for Each User Account
Job Management Manager Shutdown
The SYS$STARTUP:UJM$MANAGER$SHUTDOWN.COM procedure allows the passing of a parameter that controls the type of shutdown performed. The parameter values accepted are:
FAST
This P1 parameter shuts down the system without checking for any currently running CA Job Management Manager jobs. Any jobs currently running are stopped and requeued.
NOWAIT
This P1 parameter checks for any currently running Job Management Manager jobs. If any jobs are found, you are notified and given the option of reviewing a list of currently running jobs and terminating the shutdown, if desired. If you do not respond within 30 seconds, the shutdown procedure continues, and any jobs currently running are stopped and requeued. This is the SYS$STARTUP:UJM$MANAGER$SHUTDOWN.COM default setting.
WAIT
This P1 parameter checks for any currently running Job Management Manager jobs. If any jobs are found, you are notified and given the option of reviewing a listing of currently running jobs and terminating the shutdown, if desired. The shutdown will not continue until a response is given.
