The following table describes the manager’s startup and miscellaneous control files.
File |
Description |
DEPENDENCY.DAT |
File for dependencies, created or updated by the manager when you create a dependency. |
INSTALL_DO.COM |
Installs the job command Agent SCHEDULER$DOO_COMMAND.EXE. |
INSTALL_INTERFACE.COM |
Installs all Job Management Manager user interfaces. |
LBAL_ROUND_ROBIN.COM |
Alternative load-balancing procedure that performs round-robin load balancing. |
LOAD_BALANCE.COM |
Load-balancing command procedure. Performs dynamic load balancing within an OpenVMS Cluster. You can customize this command procedure to meet specific user requirements. |
SCHED$GET_BEST_NODE.EXE |
Load balancing file. |
SCHED$LISTENER.COM |
Runs the manager’s Remote Agent Listener. |
SCHED$SD_CLASSES.DAT |
File for Special Day Class definitions, created or updated by the manager when you create a Special Day Class. |
SCHED$SD_RESTRICTIONS.DAT |
File for Special Day Restrictions, created to record the Day Class definitions (that is, user-defined calendars associated with jobs that run only on specified dates). |
SCHED_DECNET.EXE |
Detached process listening for communication requests from remote OpenVMS machine running the manager. |
SCHED_RUN.COM |
Runs the manager’s program image. |
SYS$SYSTEM:SCHED_DECNET.COM |
Runs the manager’s remote network object. |
TEMP_PARMS.DAT |
File that contains parameter override values, created when a RUN or SET command is executed with parameter override values. |
UJM$MANAGER$IVP.COM |
The manager’s installation verification procedure. Resides in the SYS$TEST directory. |
UJM$MANAGER$SHUTDOWN.COM |
The Job Management Manager shutdown procedure that the SYS$MANAGER:SYSSHUTDOWN. COM procedure should call. |
UJM$MANAGER$STARTUP.COM |
Installs the manager’s images and starts them running. Resides in the SYS$STARTUP directory. |
UJM$MANAGER$STARTUP_LOCAL.TEMPLATE |
Provides the full list of customizable logical names, as well as usage information, to alter Job Management Manager behavior at startup time. |
