Previous Topic: Job Management Manager Installation Kit Files
Next Topic: Startup and Miscellaneous Control Files
Job Management Manager Core Files
The following table describes Job Management Manager core files.
File
Description
CPU_UTILITY.EXE
Shows the CPU rating of the local node, if available.
DB_UTILITY.EXE
Database compression utility.
NSCHED.EXE
Job Management Manager program image.
RETRY.EXE
A program image that retries the manager’s remote operations.
SCHED$LISTENER.EXE
Detached process listening for termination messages from remote Agents.
SCHEDULER$DOO_COMMAND.EXE
Run by jobs that are created by the manager. Protection must be set to W:RE.
SCHEDULER$SHELL.COM
A command shell used to execute jobs.
SCHEDULER$SUMMARIZE_LOG.EXE
Used to generate a log file summary.
VSS.DAT
The job database.
VSS_REPORTS.EXE
A log file reader/reporter utility.
