Previous Topic: Step 7. Specify the UIC of the CAUNIVMS account
Next Topic: Step 9. Specify the CA NSM Manager System
Step 8. Choose the Products for Automatic Startup
The installation displays the Product Startup Selection menu listing all the products that you can choose to start automatically after installation and asks if you are satisfied with the displayed choices, as shown in the following example:
	CA NSM for OpenVMS - product startup selection
1	CA Job Management ................................... NO
2.	CA Job Management Agent ............................. NO
3.	CA Universal Job Management Agent ................... NO
4.	CA NSM Jobflow Support............................... NO
5.	CA Job Management NSM/CCS Integration ............... NO
6.	CA Console Management ............................... YES
7.	CA System Watchdog .................................. NO
8.	CA System Watchdog NSM/CCS Integration .............. NO
9.	CA Performance Management Agent ..................... NO
10.	CA NSM Performance Trend Cube ....................... NO
11.	CA Common Services OpenVMS Gateway .................. YES
Are you satisfied with the product selection Y/[N] ? y
If you responded Yes to the question about activating CA Common Services, then the value for item 11 (CA Common Services OpenVMS Gateway) is also set to Yes.
If No, the value is set to No. If you answer "No", the UNICM event trap filter and action will not be loaded. If at a future date you wish to activate the Integration, you will need to take additional steps to include the Console Integration configuration settings (see below).
To activate CA NSM Integration at a later date
  1. Run @sys$manager:capoly$set_startup_params. Make sure that the following values are set.
  2. Run @sys$startup:capoly$startup
  3. Run the CA NSM Integration IVP by executing @sys$test:TNG$LINKS$IVP
In a clustered environment, you may not have licenses for all components on all nodes. This menu enables you to select components separately for each node. You can also customize the startup list by using the following command procedure while logged on to each node:
@sys$manager:CAPOLY$SET_STARTUP_PARAMS.COM
