Before installing the agent on your system, stop any previous version that you have running on that system. If there are active processes, the installation procedure displays them and prints the following message:
%VMSINSTAL-W-ACTIVE, The following processes are still active:
Then you will be asked the following question:
* Do you want to continue anyway [NO]?
Continues the installation procedure.
Exits the installation procedure immediately.
