Edit your system shutdown file so that the manager will shut down properly when your system performs an orderly shutdown.
Add the following command line to the system shutdown file, SYS$MANAGER:SYSHUTDWN.COM:
$ @SYS$STARTUP:UJM$MANAGER$SHUTDOWN.COM
If you are activating the Integration software as well, you only need to add the following to your system shutdown file:
@SYS$STARTUP:CAPOLY$SHUTDOWN
CAPOLY$SHUTDOWN checks for the presence of each component and, if installed, shuts it down.
