Previous Topic: Step 13. Stop CAM and CAFT
Next Topic: Step 15. Activate the CA NSM Integration Components (optional)
Step 14. Remove CAM
The installation checks for certain prior releases of CAM installed on the system. If a certain prior release is installed, it must be removed in order for the current release to be installed. The installation asks if you are able to remove the prior release of CAM from the system.
YES
Uninstalls CAM and CAFT from the system and then continues
NO
Stops the installation
