Job Management Manager common files are installed to two directories on a cluster common disk: NSCHED$COM and NSCHED$DATA. The installation procedure asks for the device where the product common directory will be located. The default device is SYS$COMMON. However, if you are installing the manager in a mixed architecture OpenVMS cluster, specify a disk that is shared among all nodes in the cluster (for more details, see "Installing on an OpenVMS Cluster" in this guide).
* Enter the full pathname for CA Job Management - (cluster) common files[SYS$COMMON:[NSCHED]]: Selected pathname: [SYS$COMMON:[NSCHED] * Is that correct [Y]?
Note: On a standalone system, the prompt still refers to a cluster common directory. You may choose to install the common and specific files to the same directory. However, we recommend choosing a directory that is part of SYS$COMMON, which makes it easier to add this system to a cluster in the future.
