Previous Topic: Running the Installation
Next Topic: How to Install the Job Management Manager
Installing Job Management Manager
Before installing the manager on your system, you should stop any previous version currently running on that system. If there are active processes, the installation procedure displays them and prints the following message:
%VMSINSTAL-W-ACTIVE, The following processes are still active:
Then you will be asked the following question:
* Do you want to continue anyway [NO]?
A NO answer halts the installation procedure and exits. A YES answer allows you to continue the installation procedure.
