Previous Topic: System Quotas
Next Topic: Installing Job Management Manager
VMSINSTAL Requirements
The Job Management installation procedure uses VMSINSTAL to complete the installation. When invoked, VMSINSTAL checks whether:
If it detects any problems during the installation, the installation procedure notifies you of the problem and asks if you want to continue the installation. In some instances, you can enter YES to continue. To stop the installation process and correct the problem, type NO or press Enter. After the problem is corrected, restart the installation.
