Previous Topic: Disk Space
Next Topic: VMSINSTAL Requirements
System Quotas
The system you install the manager on must have sufficient quotas to enable you to perform the installation and start the software.
The following minimum values recommended for system parameters are listed below:
SYSGEN parameter
Minimum Value
FREE_GBLSECTS
20
GBLPAGES
900
CHANNELCNT
256
RESHASHTBL
4096
LOCKIDTBL
3840
If you are using extended job field lengths, the DCL "pipe" command may need larger quotas. The following minimum values recommended for system parameters are listed below:
SYSGEN parameter
Minimum Value
DEFMBXBUFQUO
10240
DEFMBXMXMSG
2048
